should i buy my friends engine (4g63t) for 100$
yeti
san diego california
should i picc this up and do a full rebuild
( i also want more knowledge about rebuilding engines)
what kind of damage is un-repairable
i think he threw a rod
and its from a fwd and il be making it awd ANY DIFFERENCE?
AND I THINK ITS A 7BOLT
AnotherNewb
Orlando, FL
Thrown rod =FUBAR
Spun rod bearing repairable.
7bolt is not a direct replacement.
Is it pulled apart? Pictures would go a long way.
yeti
i was not planning on using it unless my 6 bolt goes
i just want experience i might throw it in another car,,or sell it after rebuild.....
but i will have more info on whats damaged and possibly some pictures
yeti
ok nothing wrong with engine he said. BUT ITS JUST THE BLOCK WITH PISTONS
IS THAT WORTH A 100
o and he says he can get 300$ for just the block
(is this true or is he bull shitting)
acidrumz
Stp, Mn
7 bolt? if i were you, i'll pass. If he's a real friend, you should be getting it for free. imo.
TylerAdamson
Iowa City, Iowa
Quoting yeti:
IS THAT WORTH A 100
I personally wouldn't pay anything for a stock 7 bolt. Definitely not worth the $300 he claims. The 7 bolts just aren't desirable motors and most people would probably just give them away to clear the space.
alansupra94
Wayne,NJ
Quoting yeti:
IS THAT WORTH A 100
Sounds like you need to make new friends that aren't retarded. I bought a 6 bolt block w/ 2g pistons on 1g rods with everything else besides a head for $200.
No one is going to spend $300 on a damaged block. Tell your friend to stop smoking weed and get a realistic grip on 4g63s.
yeti
hahaha /ubbthreads/images/graemlins/grin.gif
thank everyone for advice
(by the way this is the same dude who told me if i pull the awd FUSE it will be only RWD)
I WILL TELL HIM 2 FUC$ HIMSELF
slugsgomoo
Tacoma, WA
if it was a 98 or 99 7bolt, maybe. If it's 92-97 it's garbage anyway, especially if it tossed a rod. If it doesn't have a crank it's extra worthless.
2of9
IGH, MN
i bought a $50 7 bolt block with a 1g head locally just to play around with. much better than paying $200-300 for one at the junkyard.
