i'm at that point in my 2.4 build where i'm dropping the crank onto the ACLs.
This is what i've been told to do:
drop in crank, tighten caps to 20ft/lbs, then back off to finger tight, then hit ends of crank with rubber mallet to align the thrust bearing. then tighten down the 4 outer caps to 49 ft/lbs. proceed to apply force on the crank with a prybar in the direction that the clutch would normally. while applying force tighten down the middle (thrust) cap.
any other random factoids people want to remind me to do so i dont screw this spendy piece of hardware up?
