set up ????
ok so i know my goal for my car and its almost time to start buying parts i have a ebay 16g /ubbthreads/images/graemlins/frown.gif on there now when it blows im gonna rebuild with genuine parts but my real ???? is cam choice i want the car in high 11s when all done would crower 272/272 be sufficient next issue is this car is a slow process (arent they all) would 272 be ok for normal driving ive heard they would outflow the 16g sorry if i am way off i am a noob after all thanks in advanced
Brunoboy
San Bruno,CA Home of SFO
Quoting ddavidson:
eBay turbos can't be rebuilt with real parts.
guess im blind cause i did not see cam turbo combinations sorry im overlooking it
Quoting brunoboy:
Quoting ddavidson:
yes they can people do it all the time the ebay 16g turbo just not all mhi parts this is what you need
What you need to do a basic service (no thrust hardware) is:
- A Garrett T3 turbine seal.
- A pair of Garrett T3 journal bearings.
- A Garrett T3 compressor seal.
What you need to do a full service (if the turbo has in/out shaft play) is:
- A Mitsuhishi TD05 thrust plate.
- A Mitsubishi TD05 thrust collar.
- A Mitsubishi TD05 compressor seal.
- A Mitsubishi TD05 compressor collar.
- A Mitsubishi TD05 oil shield.
Brunoboy
I was saying a MHI tdo5h kit isn't going to be adequate for rebuilding your eBay turbo and if you have Togo through all that trouble , buy a real MHI turbo.
well thanks for your opinion and ill cross that bridge when i get there but for now i would like to stick to the main subject of my post thanks
Quoting brunoboy:
272/272 is a DD, street able cam choice and can get you in the 11's.
thank you
Quoting omertaitalia:
how would 272 cams outflow a 16g?
i honeslty have no idea i just read it somewhwere
Vman911
Douglas county, Ga
I'm running 272 regrinds on evo8 springs and retainers. Redline at 8200.... Drives like normal on street. I do have each cam gear set back 2 degrees. 1 is +2, 1 is -2. Very small lob at idle.
