SD galant ecmlink v3
Typhoonguy
Active member
Fox Lake illinois
So recently i had my galant dyno tuned at a local speed shop. Very happy with the performance, but.... There is an issue i am having. Any time while i am cruising an i lightly press the accelerator 2-4%tps my lc-1 will go way lean real fast the engine will sputter. I will then press the pedal a little harder an after doing that my wb will read correctly an vehicle will accelerate normal. So the man i am i want to fix it myself an really dont feel like taking another day off of work to bring this car back down to my dyno guy. I have read an read again that my issue is more likely in the throttletipinADJ table in ecmlink. I guess my question is where on that slider would i adjust for very slight throttle apply? From what i see there are 5 yellow dots on the screen, the furtherst left dot is reall high an the rest fallow down. I just dont know which yellow dot to move to fix my issue. Thanks for the help in advance guys
Steve
4thStroke
Vancouver, WA
Does it do this at any cruising RPM?
For the tip in adjustment, I believe you need to log delta (you know... the triangle thing) TPS and adjust the tip in table according to the value it gives you when the car sputters.
Typhoonguy
Active member
Fox Lake illinois
Mostly it does this in between gears, 1-2, 2-3 ect. I will notice my WB go lean as it should. But as far as it going rich again it tends to hesitate (it likes 15.5ish) an then as i press the throttle slightly harder (45ish%) she will drop airfuels like a rock the sputtering will end an i will be on my way. Anytime throttle is past 40% i do not get the sputtering
Steve
Typhoonguy
Active member
Fox Lake illinois
I also tried logging the delta thing. But when i did nothing comes up on the graph. It just reads 0.0 the entire time? I tried to figure out how to log it but couldnt
4thStroke
Vancouver, WA
Disable airflow smoothing if its not already.
Check out the ecmlink wiki, this should help at least some. =tip t=_blank]click
As far as delta TPS not showing a number while you blip the throttle, I can't add to that, I'm at just as much of a loss as you are.
Typhoonguy
Active member
Fox Lake illinois
Yeah you an me both then sir.. Lol i figured throttle position was throttle position. An when i tryed to log tpsdelta an it did nothing i was at a tottal loss. An yes airflow smoothing is disabled. Maybe i will just mess with the dots (settings) a little bit. Eh whats the worst that can happen.. Thanks for the input 4thstroke
Steve
4thStroke
Vancouver, WA
You added delta TPS to the captured values list and then added it to the displayed values list, correct? They're two different functions/steps, so if delta TPS didn't show on the log at all, the second step probably didn't take place.
My car ran perfectly fine when my TPS sensor wasn't working and read "0" 100% of the time, so that was my reason for asking.
Typhoonguy
Active member
Fox Lake illinois
I think i did all that correctly? I can see it on the graph at the bottom of the screen, but when i go to start a capture it just sits at 0.0 so im not sure what its deal is..
4thStroke
Vancouver, WA
You're best bet would be to post a log on the ecmlink forums. I wouldn't say anything about a shop tuning the car, as there are a lot of snobs on there that'll just critique the tune more so than actually help.
Typhoonguy
Active member
Fox Lake illinois
The injectors im using are 850's i know i have to go much bigger but these seem to do the job for now.. An thanks 4thstroke for the heads up. I will post a log on the ecmlink forum an see what they say. I will make sure to keep my lips sealed about the shop tune..
