SARD fpr --- which one?
belize1334
Bozeman, MT
SARD sells two models of AFPR. The regular is about $130.00 and the Type-R is about $250. Is the regular one sufficient for a Walbro 255 or equivolent? I don't want to get one of these things and find that I'm STILL over-running my fpr.
Bimmubishi
Boston, Massachusetts
I use the regular and it's fine. I have the 255 pump. We have the type R on a couple of cars and we don't really know why there are two. My car makes almost 500whp when the engine is in the car.
belize1334
Bozeman, MT
That's just the kind of info I was hoping for. Thanks guys.
As for placement. Have any of you hard-mounted to the rail using hard npt fittings or is everyone using flexible line and mounting remotely?
cOmpressor
Bay Area, CA
From what I've seen most people mount remotely but it's up to you. My choice is also remotely because of the mounting options.
GVR4_1057
Brucetown VA
I had my afpr hooked up with hard pipe fittings in my old setup. I threaded my fuel rail and ran a 90 from it into the regulator. It was all 3/8 NPT. It worked well and never gave me any problems.
belize1334
Bozeman, MT
So you just tapped the end of the rail to 3/8" npt? Or did you use an adapter.
If I go hard mounted I was planning on getting the -6 AN fittings for the fpr and using the -6 AN fuel rail fitting which appears to be a universal piece for any 1G/2G/Evo 4g63 fuel rail. Then I thought I'd just get a -6 AN 90* fitting and go from there.
My other option would be to get the 8mm barb fitting setup and just use some high pressure rubber fuel line since this setup will never see fuel pressures over 65psi anyway. In that case I'd be using the SARD Evo fuel rail adapter which takes the stock fuel rail fitting and mates it to npt.
EDIT: Apparently the SARD stuff is all BSPT and not NPT. Can anyone confirm?
belize1334
Bozeman, MT
Can anyone confirm or deny that the EVO fuel rail adapter will work with our fuel rails? The key of course being the piece that slides into the rail. If necessary I could slot the holes for the mounting bolts.
Roger, I'm pretty sure the inside dimensions of the EVO fuel rail are the same as our's, as the FullThrottle AFPR also bolted on to EVO's. But, the bolt pattern is different, but maybe the same as a 2G? /ubbthreads/images/graemlins/dunno.gif
GVR4_1057
Brucetown VA
As I recall the outlet bolt pattern on the evo is the same as the inlet on ours. I have one around but could not dig it up.
belize1334
Bozeman, MT
Awesome. I think that's the way to do it then. Get the 8mm barb version of the regular SARD fpr and the Mitsubishi fuel rail adapter, both of which can easily be ordered here if nowhere else. Then some 5/16" high pressure rubber fuel hose and a 1/8" npt to 1/8" bspt adapter from McMaster.com so that I don't have to buy a new gauge.
Thanks for the input guys.
belize1334
Bozeman, MT
If you still have it when I decide to get my regulator, I'll take you up on that. Does it have the 8mm barb or is it an AN style fitting?
