safe levels on my engine need ideas
Need an idea where for what's done to mr 651 compression is like 155 and trying to touch 158 all 4 and it has ported 14b at 18lbs I'm pushing and has stage 3 keydiver with 650cc and 2g mas compensation and my fpr is @ 39psi I also have an safc2 and front mount and 2g mani just want to have this be my dd and be pushing safe lbs and stay reliable or am I good where I sit just curious /ubbthreads/images/graemlins/confused.gif
Have cable no logger though, but my safc does not read any unless its just there on screen but the safc2 is installed proper
You should be good, i would drop boost down to 15psi max though. Bu that's me. 14b's aren't meant to hit 18psi everyday.
steve
NJ
Quoting 651vr4:
The SAFC will not read nor display knocksum on these cars.
Yeah that is what I thought safc shows on display but I knew it would not read knock lol but ill be buying palm with software on 25th payday and that's true 18lbs is a lot for a baby turbo
