Rusty fuel sending unit line broke!!!
As a few others have experienced in the past, I started doing my Walbro pump today, and the outlet line on the top of the sending unit broke while I was trying to detach it from the fuel line.
I've gone through the thread in the how-to section (linked here "Fuel system questions" )
I aim to use the same method John explained in that thread (cutting the old metal line and drilling out the plate to 5/16" and replacing it with flexable 5/16" fuel hose. What I can't figure out is what size the female connection is on the stock fuel line comming from the motor???
Also the thread left me a little confused about AN sizes. What AN size is closest to 5/16"? I am looking for a fitting that has threads on one side and a hose attachment on the other and I find them most commonly in AN sizing.
Please post up any methods you've used to overcome this problem, and the sizes of the fitting used. Any help is greatly appreciated!!!
JNR
ca
This is what I used on the connecting end to oem: M14x1.5 to 3/8" JIC (close enough to AN) "adapter".
I used -06AN line and fittings (close to 3/8") mainly cause I have a bunch of line/fittings sitting around and also it's a pretty common size.
^^ Thanks for the info. Did you run the -6 an line right in through the sender, or did you use another JIC bend? Do you have any of this stuff left over you'd want to sell?
JNR
ca
Check out that link that is posted and scroll down to my name...
I believe I do have 1 or 2 more fittings, both for the fuel sender unit (needs to be welded to plate) and the 'adapter' from -06 AN (fitting) to OEM female "nut"...I'll check later this evening and let you know.
An sizing is that number over 16.
5/16 = 5an
But you will not find 5 AN used often except in industrial applications.
AN fittings are JIC thread. I did mine the same basic way as JNR did. Welded the AN 6 fitting to the top of the housing, 90* elbow to -6 braided line, the other end a -6 straight attached to the -6/ 14x1.5 Earls adapter to the original rubber fuel line.
JNR
ca
Well, I checked and I have (2) sets of fittings left, so if anybody is interested, please let me know...IIRC, it was $15 shipped for both fittings.
Thanks,
John R.
