Running lean after egr block off & emission delete? Help please.
cupajoe
Cocoa, FL
As the title states I finally elimated all my emission and blocked the egr valve and today after driving my low trim is maxed at 139%. I can't figure out why I'm so lean after deleting this. I capped everything off, could it be a bad cap causing a leak? Any thoughts would be appreacated. Thanks.
Any luck yet?
I would test for leaks. Theres a section in VFAQ on building an inexpensive tester just in case you haven't seen it.
