running a sohc ka24 on a dsm ecu.
presterone
brunswick maine
My friend is going to try and run his datsun with a turbo ka sohc engine on a dsm ecu with a jackal speed density setup. I think the largest hurdle will be machining something to run the crank angle sensor off of the distributor. If anyone has any input or similar experience let me know. I've heard of people running hondata ecus with toyota 3sgte engines so I don't see why this wouldn't work.
5OF2k
colorado springs, colorado
You can definitely do it. There is a guy here in the Springs running a Miata with a DSM based turbo setup on it, runs a 1g ECu and Link V3 in SD. It can be done, it'll just take some wiring and so-on. Also be prepared to use a DSM gauge cluster.
-Jake
presterone
brunswick maine
So the ka24 distributor spins the same amount as the crank where on our cars the CAS spins x2 faster than the crank. We may be better off slotting the cam to mount the CAS.
toybreaker
iconoclast
Quoting presterone:
... been drinkin ... but that doesn't sound right
I *believe* our cams/cas spin half speed, same as the cams/dizzy in the ka motor
(takes two revolutions of the crank to make one turn for the cam/cas/distributor)
... The cas *should* be relatively easy
Just gut the nissan distributor, ginzu the distributor housing as required, (leave the top bearing a long service life) and then fab a drive/slot on what's left of the o.e. shaft.
A slotted collar *might* just work tits
(collar that presses onto the o.e. shaft with a drive slot cut into the top to spin the cas)
get it lined up/set up where you like it and then drill/pin it or break out the welder and make it permanent. /ubbthreads/images/graemlins/devil.gif
done
Now, the injestors may be another story
... isn;t that a side feed injector set-up?
presterone
brunswick maine
Haha yea I had it wrong woops! im not sure if the nissan injectors are top or side feed. Worse case scenario we have to fab up a fuel rail, no biggie.
You may definitely do it. There is a guy here in the rises operating a Miata with a DSM centered turbo compresseur installation on it, operates a 1g ECU and Web link V3 in SD. It can be done, it'll just take some cabling and so-on. Also be ready to use a DSM evaluate group.
tektic
ronkonkoma, ny
The Nissan ecus are just as tunable, So unless its just for bragging rights you might as well stick with the Nissan stuff. Your going to be fabbing parts of sensors and or extensively rewriting code to make it work right. It can be done just not as easily as some other ways.
presterone
brunswick maine
But not for the money. He was looking at a nistune setup and it would be almost $600 to get the setup and then it would take a long time to learn how to use it. I can at tune with jackal good enough to get it running and we have a dyno in my garage to get the car dialed in perfectly. Considering I have a lot of the parts that he will need and weighing up the costs this is the one of the best options. No I would not just do this for bragging rights we both make very little money.
tektic
ronkonkoma, ny
If its odb1 I have a basic tune I can send you. You need a daughter board for the stock ecu and a prom burner. Should cost abou t $100 for both
