Revving in speed (was the abs)
When i drive faster then around 15 and push my clutch in, the engine revs to around 3000rpm. This happed even if the car is in neutral.. But when i drive realy slow or stopps it goes down to 800rpm right away.
What could cause this ? I have tried to clean the trottlebody and the ISC.
Maybe i could block the isc?
It is a jdm gvr4 rs.
I found out what the problem was. It was because i had a fault code in the ABS system because it had not been properly removed. So i took out the ABS computer and then everything was normal!
Struc
Oconomowoc, WI
Yes, it does. Same thing happens if you pull the large ABS fuse in the engine bay (On the 4-fuse block attached to the battery post). Found out when it happened to me (ABS hasn't worked since I bought the car - figured I'd pull the fuse).
Keydiver made a post about it years ago that came up on a search that solved the mystery for me.
