rev limiter????
squintz13
easton,pa
Ok i was trying o hook up my stutterbox i looked at the clutch switch and it looks like someone cut the two wires from the connector and twisted them together.. i disconnected the connector and the car still started.. so i spliced into the blue wire on the switch and into the Pin 104 which i believe is located on the smallest plug top row second one in and pushed the clutch in and reved it out....nothing happened but while i did this i noticed a hesitation at like 5k and then i just flew all the way two like 9k isn't there a rev limiter what could be wrong with the way I'm trying to hook the stutterbox up and why doesn't it work....pease help
Are you sure you're working with the LOWER starter interface clutchswitch? What color is the wire that is cut? You should be working on the wires AFTER the connector, not between the connector and the switch, as I don't know the colors of the actual switch wires.
squintz13
easton,pa
The wires that were cut are before the switch it just a conector that plugs into the switch conector they are black/one white dot and another with two white dots along the wires.. after that conector there is a looks like blue wire and a black wire the that go straight to the switch.....do i have Pin #104 right....
fastasleep
Christiansburg, VA
Pin 104 is a black wire termed the 'Neutral safety switch' (AT only, grounded in MTs).
Run a wire directly from that to the clutch switch connector wire (black with red stripe, NOT green!).
squintz13
easton,pa
ok im a little bit cunfused....i dont have a a wire that is black and red unless im looking at the wrong switch.. the one im looking at is the bottom one and is pressed in when the clutch peddle is pushed all the way down.. there is also one on top that releases when clutch peddle is pushed.. (not the one im looking at)... does any one have a picture of theone i should use.. And do i completely cut the wire on pin #104 or do i just splice into itt......
AFTER the connector, not between the connector and the switch.
And, yes, you have to cut the black wire on pin #104 completely OFF, as it is a GROUND wire.
