[Resolved] Door Locks Issue After Clutch Pedal Install
KiNgMaRtY
Corona, CA
So I had my clutch pedal rebuilt by Shephard. After putting it back in and connecting all the sensors back, if I try to push my door locks down, they just pop right back up. I assume I must have missed something? What could I have left unconnected?
KiNgMaRtY
Corona, CA
With the door opened they will not go down.
They will stay down with the door closed but the alarm green light will not come on
mitsuturbo
Near Seattle, Washington
Does your key buzzer make noise even when the key is pulled out? If the button in the ignition switch thinks there is a key in there, you won't be able to lock the doors if they're open. This is to prevent you locking the keys in the car, at least while they're in the ignition.
KiNgMaRtY
Corona, CA
No it does not make noise when they key is out. They wont go down even with no key in the ignition
KiNgMaRtY
Corona, CA
Also the car starts and drives, just the issue with the door locks (and the clutch pedal not being the issue /ubbthreads/images/graemlins/frown.gif )
I will have to disconnect and connect all to make sure that they are tight. I was just wondering if there was a particular one that I should looking out for
mitsuturbo
The car starting and running actually has nothing to do with the "key inserted" button wiring. However, this button does tell the system that there is a key in the ignition, and not to allow the doors to lock while open.
KiNgMaRtY
Corona, CA
Thank you for all the help! I pulled the cover around the ignition and followed the wiring to the harness that was indeed left unconnected. I found the the other connector tucked away and connected them. Issue resolved!
