Replacing Water Pump Without Doing Timing Belt Job
It's been a long time since I did the timing belt on the car. So not quite too clear... The only thing I should really have to worry about removing is the belt, alt. for the most part, timing covers, and...?
Sorry, getting back into the car again for the first time in a while.
1990ggsxnj
Blackwood, NJ
The water pump and crank pulley need to come off too. I don't remember having to do the timing belt to change the water pump but it's a big pita if you don't at least take it off. With all of that, might as well just do the timing belt.
I just did a 2.4, and it might be different, but I had to remove the tensioner pulley lever portion to get one of the water pump bolts out.
Barnes
Richland, WA
Quoting iceman69510:
I remember this being the case on our cars. Sorry, gotta take the t-belt off. /ubbthreads/images/graemlins/frown.gif
