Replacing speedometer cable
jrschultz
Active member
Oconomowoc, WI
I have to replace my speedometer cable soon. I found a thread while searching that describes how to remove the cable from the transmission. How do you remove the cable from inside the car where it's behind the gauge cluster? I know how to get the gauge cluster off. I had to do this to verify that the cable wasn't spinning. Do you have to remove any more of the dash besides the gauge cluster to get the cable free? Please advise if you have done this before.
donkeylips
Rochester, NY
There's a large white clip that holds it in behind the cluster. Easy as pie to release, then it should slide right out. I just pulled one off of my parts car, since the one on one of my Galants gave me a really hard time coming out of the transmission.
jrschultz
Active member
Oconomowoc, WI
Thanx for the quick reply. Is it easy to fish the speedometer cable from the engine bay to behind the gauge cluster?
donkeylips
Rochester, NY
I did it the other way(pulled it out through the engine bay) last time. Not sure if it can go the other way or not. The dash was out when I did it, but I don't think it would be too hard.
