refurbishing the rear subframe
While I have mine out I plan to paint, install some poly bushings, and eccentric bolts. I was also thinking about wheel bearings and ball joints as well, sound like its worth it? I know the bearings are a good idea, but I think I can get away with the ball joints I have...
The rest of the rubber looks good, even the mustache bushings, but they are included with the poly sub bushings. What do you think?
Ordered some ES sway bar, upper, and lower control arm bushings and wheel bearings. Still thinking about ball joints...
DynastyLCD
Harwinton, CT
last year i did a partial rear subframe overhaul. i tried to knock out as much as i could afford to at the time. i did custom upper and lower control arms, poly bushings, toe eliminator, sway bar relocation, poly sway bar bushings, custom end links, and i was very happy with the results. the poly bushings will make your rear end very noisy, if you have a carrier bearing that's worn, or a driveshaft bearing, or even an unsprung clutch, get ready for the decel noises. after the work i did, it felt like it handled a world better. the car stays planted, also has k-sport coilovers.
next up to tackle is the wheel bearings, and then its going to stay like that for awhile. you'll be happy after you complete all that work. i felt a dramatic difference afterwards, going from a 140k subframe to a revised and restored version.
I'm going with the softer poly subframe bushings from boostx, which did you go with? I'm assuming that would cause most of the increased nvh?
DynastyLCD
Harwinton, CT
ah jeez, i forgot which ones. they were green. i think it was the tunersnation ones. bought them last winter. there was no option for stiffness, they were all the same.
yes, i would agree that the poly bushings were the leading cause of increased NVH. maybe the softer ones will change that?
