Recommend me a Machine Shop in Denver
Based on some feedback from some members, I'll just pull my head and have it gone over. New valves and such. The motor was a swap, so it has lower miles than the chassis at 160k. Not sure of the exact mileage on the motor.
In any event, what is a good machine shop in the Denver area. Westminster/Thornton/Northglenn area. Also, would just a valve job do the trick?
Also, I've never taken a timing belt off but I know I'm not going to be re-using it for sure.
Struc
Oconomowoc, WI
No need for new valves most likely, but a valve job is a good idea. New valve seals, cam seals, etc. While in there, would be a good idea to upgrade to 3G lifters if you have any lifter tick.
In addition, depending on the miles of the the engine, you should consider replacing other timing components as well, while you have the timing belt off.
Both idler pullies
Timing Belt Tensioner
Balance shaft belt & tensioner, if still on the car
Water pump
And if you REALLY want to be cautious, replace the oil pump assy or pump gears.
Well, the car jumped timing and the valves hit the pistons, I'd think new valves would be in order. All the the timing components will be replaced. Lifters are a good point, no tick but mind as well. I'f I'm not going to save the timing belt, do I really need to take special attention while "removing" it.
Struc
Oconomowoc, WI
nope. A utility knife would do just fine removing it. /ubbthreads/images/graemlins/grin.gif
Didn't realize it had jumped timing. You'll want to have the guides checked out and replaced if out of spec as well then.
