Rear Window Ariel and Defogger (JDM rear Wiper Cars): Tech Info, Service and Wiring
misterfixit
Midlands, UK
Tech Info Manual:
Service Manual (Apologies for the state of some of the page Scans (I'll clean these up when I can)
54-75 (Condensers and stuff for SOHC cars only)
Wiring :
Section C Inner Firewall Config Diagrams
Section F Rear Config Diagrams
Rear Defogger
CD 6 Speaker Stereo Wiring (With Ariel)
@AllanL
Hope this is what you need.
Rich
PS. This is for the 87.10 model year. The only changes they made over the production run was 89.10 the new kick panel fusebox with slightly different power distribution. Core circuits are the same.
misterfixit
Midlands, UK
Here is the wiring (Allan I linked your pic)
i-img1200x900-17402144885427iorkoy19364-jpg.5341
The white box fits through the parcel shelf steelwork from the top. The two wires for the defogger run left to right from there and up the c pillars.
The tin box is screwed into the left hand c pillar about 2in from the top in a recess, You use the dome head sheet metal screws that are the same as used to hold the very front plastic on the main centre console moulding and the inner side of the rear entry kick panels (under the seat)
The box screws in with the wire hanging down, it then loops up and clips in along the inside of the roof rail and down the left hand a pillar, across the reinforcement between the a pillars and reails down the inside of the bolt in support frame behind the dash.
(it's the double black cable here):
The glass antenna wire trails back on the c pillar and pops out of the second cut out in the left hand c pillar trim Here:
Rich
