Random Pulled Wire...
Lukefraizer
Fort Collins CO
So I was doing the jays alt relocation kit... the long way.. redoing all the wires and such to it. But when I was looking at the old location there is the wire that goes into the oil pressure unit than there is the 2 that go to the voltage regulator than the 2 that go to the main fuse block (the 4 input with all the ABS stuff. Than there is one other wire and I can't figure out for the life of me where it is supposed to go. Looked at some alldata stuff and I can't find the wire on there and was wondering if anyone knew where it goes to... also is there anyone that knows where the Voltage regulator wires are supposed to go to? I know one goes to the big fuse box #5 under the hood but I can't find the other wire anywhere in the engine bay It says it is supposed to go to relay and the dash light at the same time but I cant find the place where it is supposed to splice.... If I'm the only one ever to have done it this way than I would be surprised but I will have to work it out if I am. But any help would be amazing!
Luke
Adorsey
mass
I think the one random wire may be the wire that goes to the power steering pump. I deleted my p/s but im almost sure, as this wire you did not mention but is down in that area.
Lukefraizer
Fort Collins CO
I feel like the ps pump is the only one it could be but where would it even plug into? I don't see any area on there for it to plug into.
Adorsey
mass
The p/s pump you need? There is a little 'post' that the wire goes to on the pump. Almost looks like a small vacuum barb lol
