Radiator fan sensor replacement
conradical
Everett, WA
So I am needing to replace the fan sensor on the top of the coolant inlet on the engine. The pigtail on the sensor is bad and because you cant get the pigtail anymore I was going to replace the sensor with a GM equivalent. I'm not sure of the diameter of the threads or if anyone knows of a good replacement sensor and pigtail. Let me know what you guys think or what has worked in the past.
Cheers Derek
