Radiator Fan issue
napajs13
Active member
Webster, NY
With my car off (not runningg) my radiator fan was not spinning when I turn the a/c on high, so i tapped it with my finger then it started spinning slowly. So i replaced it and turned the ac to high and the replacement was spinning at what looked and felt like normal operating speed. Then I started the car and it was running for a bit, until a few seconds later, it stopped like the previous fan. Would the temp sensor in the radiator cause this problem? Any suggestions? Any info would be great. Thanks!
yeti
san diego california
Try jiggiling fan wires.mine stops working some times so i have to jiggle wires and it will work..
Im guessing its the old brittle wires that sit next to.rad. There whole.life
