Long story short, took deliver on car before mechanic finished cause was taking forever. Was told I should replace rack and pinion in the front; haven't been underneath yet to check ps lines to front and back. Options and opinions?
A good place to start is diagnosing the exact problem. I'm not too familiar with the 4ws system, but I'm sure some more experienced members can help you out with problem areas to check.
My front rack was leaking, so I just went ahead and took my entire 4ws system out, and installed a dsm rack that I had laying around. I found it easier than having to rebuild any parts, and it leaves less room for something to get messed up later on.
But a diagnosis should come first... you could still have functioning 4WS if you wanted it... if you're willing to fix it. For that, you need to know just what is wrong.
If you get tired of chasing the problems, though, a 1G rack bolts right up.
