KiNgMaRtY
Many of us have been wanting a solution kit that will allow us to bolt up the rear Brembos and still allow us to retain some use of a parking brake. I would though like some more info on what all is involved to to install the evo parking brake. Will we need a a need lead to activate or will our OEM wire bolt up to kit. I assume we will need the Evo rear parking brake guts.
I posted a questions and they will be posting a how to soon.
From their Facebook post:
vr4 rear evo 5-9 brembo caliper conversion kit $350nz
we have design a weld on brake bracket kit to fit evo 5-9 rear brembo calipers and rotors onto the 89 shape vr4. these are also made to fit the evo 4-9 internal handbrake assembly if required at the same time
the kit includes:
2x weld on brake mounts
1x template for hole locations and holds brackets in position for welding
4x cv spacers to move hub flange out 6mm for stud to handbrake shoe clearance
all bolts needed
we will also be putting a step by step photo guide on this racefab facebook page
the kit includes:
all bolts needed
