Problem with tranmission
misfitsnemesis
bristol TN
Okay got all the CEL cleared on 602 the other day. About a mile down the road heard a random DSM bolt fall out from under the car.
Well kept going on my way noticed it wasnt wanting to go into gear about 2 miles down the road. Stopped started looking
for the problem. Well noticed when you press the clutch in the motor and trans is wanting to push away from one another.
Also noticed two tranny bolt missing. So guess that would be the reason of why its doing it. My big concern is though is why did the bolts back out? Has any one else ever had this problem befor? Should i check anything else with my trans to make sure no other damage was done?
vibration? not tightened down enough before? just use some loctite next time /ubbthreads/images/graemlins/grin.gif
I'm guessing you did a swap or some work and left the bolts loose. I've never seen the bolts back out when installed properly.
Either that or maybe you have a friend who thought it would be funny?
misfitsnemesis
bristol TN
I would guesss vibration or something then. Cause i havent pulled motor or anything yet still the 182K OEM one.
moidsm1
Tucson, AZ
DO not drive the car like that, Ive broken a bellhousing that way. Get the bolts back in ASAP. Im agree that they probably werent torqued properly.
mitsuturbo
Near Seattle, Washington
Agreed. When you replace the bolts, make DAMN sure the "special" tranny bolt is in there too! By special, i mean the one with a 12mm head with the #10 embossed in the head of it. It goes near the driver side axle.
I've seen 3 cracked/broken bellhousings because this bolt was left out by shitty technicians.
misfitsnemesis
bristol TN
Yeah i didnt drive it i towed it home.
Waiting till i get paid to go ahead and do a clutch and such ordered some new bolts. But want to check the tranny first and make sure no major damage was done.
