power windows not working
As the title states my pw aren't working. Ive checked and swapped the fuse and relay with no success. Not sure where to go from here, none of the windows work on any of the switches and it seems the windows are the only electrical thing not working. Any advice would be appreciated.
boosted_85
milwaukee, wi
start at the fuse and check to see if there is power to the pw fuse. If there is pop off the main window/door switch from the door card and check to see if you have power coming up to the switch. That would be able to tell you if there is any shorts in that circuit.
Checked for power at the fuse and there IS power going to it. Have yet to check at the switch, because I'm not sure how. if theres a way to wire the switch straight to the battery please let me know. Thanks
Thanks for the perfect thread to look at. This ended up being my exact problem, bad ground to master switch. Thanks for the help!
