Power steering switch.
gvr4ever
central Indiana
Okay, I think I have everything working properly on my car except one thing. The PS switch doesn't kick on. I've hooked up a logger and the button is just solid. The cable did come undone at some time. I've put it back, but I wonder if it's tight enough or something. I've traced the wire back to the alt. I was thinking of soldering it on.... Not sure.
Anyone else have this problem. I really want to take care of this soon. The car is running better then ever, and I want to fix this last issue (for this week).
Get a new connector from a pull and save yard or make a butt connector work. You also may have a bad sensor.
gvr4ever
central Indiana
Well, the connector is still on the wire, but I'm not convinced it is making good contact. I guess I could solder it, and if it doesn't work, I can undo it.
Can the switch be bought without getting a whole new pump?
Quoting gvr4ever:
I'm not sure what you meant by this, but the wire *should* be connected to a post that sticks out the front of the power steering pump, not the alternator. /ubbthreads/images/graemlins/dunno.gif
Its easy to test the wiring and ECU: just ground the wire and see if it changes on your logger. The power steering pump is supposed to ground the wire whenever the fluid pressure rises.
gvr4ever
central Indiana
Well, ya, I know it attaches to the PS pump. After that, it goes to the alt. I could have been more clear on that. I wanted to make sure the other end was attached, and it was.
