Power steering question.
Yohler
New Lenox, IL
I'm trying to get my JM fab battery tray in and neglected to factor in the power steering lines that go over the trans into the equation. From what I can tell from the FSM and a few posts on here those are the rear steering low pressure lines, or am I wrong? They need to go to get the battery in, and I've got a 4 bolt rear on the shelf waiting to go in anyhow if that's the case but I want to be sure first.
thomcasey
Indianapolis, IN
Yes, those are the low pressure lines for the rear steering. They will spew fluid until you remove the rear steering and disconnect them from the PS reservoir.
