Power Steering Feed Line Bolt
I snapped the head off my P/S feed line bolt and was wondering if the same power steering feed line bolts are used in all other DSM's turbo or non-turbo. I noticed the other dsm's you take off a nut and have to "extract" the feed line bolt from the power steering, where our VR4's just have 1 solid bolt with a 17mm head. Will the other dsm ones work?
Are you talking about the banjo bolt on the power steering pump? If so them yes.
mitsuturbo
Near Seattle, Washington
Quoting towman:
Never have i seen a power steering pump with a BOLT going into it from the top on a DSM or Mitsubishi. Not on a 1g. Not on a 2g.
I think you've had something replaced with inferior product in the vehicle's past.
Yea I guess its the banjo bolt. Its the bolt that is hollow on the inside to run p/s fluid to the p/s pump. I will extract one from pick'n pull. Thanks guys
