Power steering cooler questions
First off, I'd like to know if you all even think one is necessary for a street car. I haven't even had the factory tube in place since I front mounted my car, and haven't noticed any ill-effects from removing it. I don't do anything like autocross or time attack, just street driving and the occassional drag race.
Second, how big is too big? The cooler that I'm planning on using is about 10"x10", 1/2" thick with dual 3/8" clamp on hose fittings. I already have this cooler which makes it more convenient than anything else. If you guys say that it is too big, what size would be best?
Also, I was told that there was a mod that could be done to the pump (I think) for better pressure output? Does anyone know anything about this?
broxma
San Antonio Tx
On a street car you should never see any problem. I took mine off when I put the FMIC on and never an issue.
/brox
Thanks for the responses guys. I guess I'll be saving the cooler for another project down the road.
vr4play
Cincinnati, Ohio
If you have one I would use it. I have what I thought was a fairly large sized cooler for the power steering and it gets fairly hot. You may not notice any issues but the extra heat is killing the components of the system. If I were going to do it again I would have gone bigger that what I have. Heat is the number one killer of most automotive components.
rdomeck
Indianapolis, In.
Not saying taking it off is wrong, but a lot of manufactures install them for a reason...Not because they have the extra parts laying around, but because they need them. Now that might be for warranty reasons or something else. I plan on leaving mine on. If there is a problem I would probably fix it or replace it with a larger one! Just my opinion!
can someone post pics of their power steering cooler because mine has been deleted
There isn't a 'true' cooler installed from the factory. There is a metal tube that is used to loop around in front of the radiator, which would recieve airflow at speed and provide some cooling of the fluid. But because it lacks sufficient surface area to truly function as a cooler, it is my opinion that it is really there to increase fluid capacity, which would inherently also help keep temps down.
