power spark and fuel but no start?
I have power from the battery, fuel to the rail and spark off the wires the car cranks but will not start. Does anyone have any idea what this could be?
Diego
Hi, have you checked the ecu for bad caps or acid leaks, maybe also check the connection points (2 plugs, I oval like shaped, the other like a round triangle) those you normally unplug when your trying to prime the motor and don't want it to turn over.
Diego
Have not checked caps yet I will do that when I get off tonight and the connections your talking about are evidence right?
Did this just happen one day or did you do some work to it? It takes power, spark, compression for a running engine. Is one of those three. You may have power at the coil wires, but what about enough spark to just the plug gap? You have fuel at the rail, but are the injectors opening?
Check you compression too while you at it. At least you can eliminate some ideas.
I bought the car with a boost leak put all new hard pipe in and changed the plugs alternator and battery and now just trying to finish it up this is the first time I tried to start it in a while but it ran when it had the boost leak.
JSchleim18
Long Island, NY
Check the BISS screw? It's the little screw on top of the throttle body facing the front of the motor. It may have been turned in too much to compensate for the boost leaks /ubbthreads/images/graemlins/dunno.gif
I don't know if it will stop the car from starting
Checked connections and pulled off the fuel rail all the connections look good and injectors are firing
If anyone is in Denver I can get you food beer money I just need this fanned thing to start I am off all day today
