Pot 182/1000
pot
Fayetteville, NC
<b>Owner:</b> Supoj Patchana
<b>Message Board Name:</b> Pot
<b>Year: </b> 1992
<b>Number: </b> 182/1000
<b>Best 1/4 mile time:</b> 14.42 @ 95.85 (5/22/11) *Leaking boost all over the place
1992 Mitsubishi Galant VR-4 #182 of 1000
JA3CX56UONZ0006950
Nile Black (X68)
<b>ENGINE</b>
<b>Intake</b>
- AMS VSR (www.automotorsports.com) *Ebay Auction, last one made $ 600.00
- ’90 NT Throttlebody (www.throttlebodys.com) *Tapered/Polished bore $ 165.00
- K&amp;N Air Filter part no. E-2875 (Advance AutoParts) $ 44.94
- 2.5" to 2.75" Silicone 90° Elbow (www.siliconintakes.com) $ 19.99
- 2.5” to 1.75” 45° Degree Elbow (www.siliconeintakes.com) $ 19.99
- T-Bolt Clamp 3”, 2.75”, 2.0”, 2’ Ft. Straight Aluminum pipe $ 20.19
<b>Total</b> = $ 870.11
<b>Exhaust</b>
- EVO III O2 Housing (www.ebay.com) $ 95.66
- RRE Downpipe 2.5” – 3” (www.roadraceengineering.com) $ 230.00
- RRE Cat-Back Exhaust 3” (www.roadraceengineering.com) $ 430.00
- HKS Carbon-Ti Muffler (www.extremepsi.com) $ 375.00
- 4 Layer Metal Exhaust Manifold Gasket (www.roadraceengineering.com) $ 34.00
- 7cm SS Turbine Housing (www.roadraceengineering.com)
<b>Total</b> = $ 1,164.66
<b>Head</b>
- HKS Camshafts 272 part no. 2202-RM005 (www.extremepsi.com $ 329.00
- HKS Camshaft 272 part no. 2202-RM006 (www.extremepsi.com) $ 329.00
- Valve Cover Hex Bolts (www.extremepsi.com) $ 14.95
- Felpro/Valve Stem Seal part no. SS70359 (AutoZone) $ 28.99
<b>Total</b> = $ 701.94
<b>Miscellaneous</b>
- RRE Catchcan (www.roadraceengineering.com) $ 54.00
- Fuel Feed line -6AN part no. PSI-FPRK-Feed-O EM BK (www.extremepsi.com) $ 59.95
- NGK Spark Plug Wires part no. ME64 (www.ebay.com) $ 41.59
- JMF Fabrications Coil Bracket part no JMF DSM-CPBKT-00 (www.jnztuning.net) $ 39.99
- 10ft Black Nylon Tubing Kit for Mechanical Pressure Gauges
part no. CON-009(www.egauges.com) $ 10.79
- Extreme PSI DSM 4g63T Stainless Steel Valve Cover Bolt Set
part no. PSI-VCBK (www.extremepsi.com) $ 14.95
- Boost Control Solenoid Restrictor Removal $ Free
- Silencer Removal $ Free
- Powder Coat Cam Angle Sensor (www.jnztuning.net) $ 8.00
- Powder Coat Upper &amp; Lower Thermostat Housing Black Chrome $ 23.00
- Powder Coat Fuel Rail Black Chrome $ 25.00
- Powder Coat All Bolts for above 3 parts Black Chrome $ 6.00
<b>Total</b> = $ 283.27
<b>Drivetrain</b>
- Driveshaft Support Bushings part no. TSGADSB
(www.tunersnation.com) $ 39.00
- ’93 Eagle tsi Shifter $ Free
- Symborski Shifter Kit part no. 2155591 (www.extremepsi) $ 36.00
<b>Total</b> = $ 75.00
<b>Interior</b>
- ARC Shift Knob part no. ANT4502 (www.lancershop.com) $ 109.95
- Alpine CDA-117 (www.crutchfield.com) $ 349.00
- HKS Turbo Timer Type 1 part no. 41001-AK010 (www.extremepsi.com) $ 124.00
- Turbo Timer Harness part no. GRE-15930002 (www.extremepsi.com) $ 15.00
- VDO Boost Gauge part no. 150-121 (www.egauges.com) $ 30.00
- VDO Water Temperature Gauge part no. 180-101 (www.egauges.com) $ 38.75
- Momo Steering Wheel w/ Boss Kit (www.galantvr4.org [member: mx4] $ 130.00
- Curtis DIN Gauge Panel (www.galantvr4.org [member: Curtis]) $ ?
- Palm M Datalogger MMCD $ Free
- ADL Datalogger Cable (www.ebay.com) $ 24.99
<b>Total</b> = $ 821.69
<b>Exterior</b>
- None
<b>SUSPENSION, WHEELS &amp; BRAKES</b>
- Stainless Steel Brake Lines part no. TN-E39ASSBL (www.tunersnation.com) $ 119.00
- Brake Pads Wearever Silver part no. MKD530 (Advance AutoParts) $ 18.99
- Whiteline Front Swaybar 24mm Non-Adjustable part no. BMF60X
(www.tunersnation.com)$253.92
- Whiteline 22mm Adjustable Rear Swaybar part no. BMR60Z (www.tunersnation.com) $ 187.00
- Cusco Strut Tower Bar OS, Front part no. 517 540 A (www.galantvr4.com) [member: RvlutionMtrsport] $ 180.00
- Cusco Strut Tower Bar OS, Rear part no. 517 541 A (www.galantvr4.com) [member: RvlutionMtrsport] $ 330.00
<b>Total</b> = $ 1,088.91
<b>Grand Total </b> = $ 4,943.58
*Grand Total omits Shipping &amp; Handling charges
<b>VENDORS</b>
- www.roadraceengineering.com
- www.tunersnation.com
- www.extremepsi.com
- www.jnztuning.net
- www.machv.com
- www.dsmparts.com
- www.siliconeintakes.com
- www.snapon.com
- www.matcotools.com
**Many thanks to the following members who have assisted me in the path from my humble beginnings dating back to 2003 as a member of the JSB crew. Many of these members whether they realize it or not, have helped me simply by willingly sharing their knowledge and experiences with others:
Curtis
Toybreaker
Iceman
Number3
89Mirageman
BlackSheep
Turbowop
Garfield Wright
Ryan Hertz
<b>Completely Stock when Dynoed</b>
<b>Still kinda sorta stock</b>
<b>Ebay Auction 1 of 6</b>
<b>Ebay Auction 2 of 6</b>
<b>Ebay Auction 3 of 6</b>
<b>Ebay Auction 4 of 6</b>
<b>Ebay Auction 5 of 6</b>
<b>Ebay Auction 6 of 6</b>
<b>Window Sticker</b>
<b> Safety Recall Notice (Transfer Case)</b>
