Possible power steering problems?
alansupra94
Wayne,NJ
Well I noticed when going into 4th gear there seems to be a very decent humming sound. It goes away when I start turning to the right but comes back as soon as I am straight and/or turning to the left. Fluid levels look fine.
Any ideas?
Lancer99
Somewhere over the rainbow
How fast are going? Do you know where the noise is coming from like from frontend, rearend, or underneath you? Just a couple of questions because I kind of had the same issue but once the noise got louder in 4th gear, it turned out to be the rear diff. going out. My problem also at times went away when I turned too, either left or right. You may also want to chack rear diff. and the transfer case fluids, just in case. If im wrong on all this others will delete it, correct me, or tease me.
alansupra94
Wayne,NJ
I will have to double check in a bit....car basically crapped itself and i am going to rebuild it.
