Poly Bushing Grease
Dan D
Brownsburg, IN
I need to re-grease a couple bushings so my car stops sounding like a sea lion over bumps. I don't have any of the ES or Whiteline grease left-over.
I've seen this Super Lube recommended before and I actually think I saw a tube of it last time I was at harbor Freight. Anyone used it?
Clicky
I've also seen Napa Sil-glyde recommended before.
What grease have you used that works well on poly bushings and where do you get it?
I don't know what where to get the good stuff, but Superpro (Whiteline) has a polyurethane grease specifically for poly bushings.
Dan D
Brownsburg, IN
Use silicone grease that you can get at hardware store for greasing o-rings.
That's kinda what I was thinking. I've got some dow chemicals silicone o-ring grease we use at work and it is very similar to the stuff ES sends with their bushing kits.
As for black grease - do you mean regular old bearing grease? Petroleum based products break down polyurethane, pretty quickly.
lol i've had my ST sway bars on my 240 for years and they still dont make any noise. i'll keep this in mind though /ubbthreads/images/graemlins/smile.gif
