Passenger Axle Retaining Ring
Dan D
Brownsburg, IN
A while back when I was tearing the car down, I had the snap ring on the axle get stuck in the tranny. It's finally time for thing to go back together and I need a new ring for the axle.
Anyone know the right size if they can be readily had at a hardware store or parts store?
rgeier11
Chicago Suburbs, IL
First, did you get the old one out?
Second, I bet someone on here has a bad axle laying around that they can take the ring off and send you.
Dan D
Brownsburg, IN
The tranny's been rebuilt since the "incident" and the missing chunk of ring was rescued and then scolded.
I've got to place an order for a few oem odds and ends. If it's not something someone has found at a local store, I'll just order one. I see in ASA there is a distinct part number for just the ring.
bcallahan92
Browns Mills NJ
4 bolt rear passenger side retaining ring needed, can’t find the part number or any available. I know it’s an old thread, can someone help me out or point me in the right direction.
