jepherz
Just a few simple questions on the AWD system on a STOCK galant vr4 that I'm a little confused about...
As far as I understand it, we have an open front and rear diff on our cars from the factory. What this means, is if one of your wheels starts spinning (let's say you're on ice) then the other wheel will get no power. Does this sound right?
Now I'm confused on the center diff. As far as I had always thought, it is either:
1. a 50/50 F/R split when traction is not an issue, and can transfer power from 100/0 to 0/100 when needed to the wheels that HAVE TRACTION. This would explain why all tires should be replaced at the same time and also why you should only tow the car on a flatbed. If this is the case, what are people gaining by buying a better center diff?
or 2, the center diff is open just like the front and rear and functions the same. I could then see why people upgrade the center diff, as it seems as soon as you lose traction in one corner, you are SOL.
Can someone explain how the system works?
