CP
I got home yesterday barely able to shift the car into gear.
for some reason, I've had to screw the clutch rod into the master cylinder about a turn every month for the last few months. The engagement point keeps getting closer to the floor. No leaky slave boot, not much weep from the rubber stopper o nthe back of the master cylinder, bled it 3 different times, stainless line.
For the last few weeks, the engagement point starts on the floor, then moves up near the top during my 45 minute commute. In between, it moves all around. I've got the rod screwed about as far into the master as it'll go, evidensed by the fact that I can barely see the end of the rod because it's turned so far into the clutch pedal connection.
WTF is going on here? My last OEM master cyl did the same thing, so I replaced with this stock 1G unit sometime late last fall. I've ordered a new unit from Advance Auto, hoping that a manufacturer switch may produce better results.
I've never seen the inside of a master cylinder, but is it possible that the rod is screwed too far into the cylinder bore, resulting in something funky going on with the plunger/stopper/seal, producing the moving engagement point I've experienced?
Could crankwalk be an issue? I'm pulling the transmission this weekend to swap in my spare and inspect the flywheel/clutch parts. Could a loose pressure plate cause this? I'm f***ing fed up with this car, and am driving my track car to work for now, which sucks donkey balls and isn't all that safe to do.
