Old Ford wheel bearings.
Spyder
Des Moines, Iowa
I had the kingpins replaced on my work van about two months ago. New Kingpins, bushings and end links. They reused the wheel bearings.
This is on a 91 Ford E-250. 2WD
I then took the van to another mechanic I use because there had been a bad vibration in the driveline. They called and told me that the whole front end was loose and needed to be rebuilt again.
I had it towed to the original mechanic that did the work. He said everything was tight according to Ford spec.
Today I jacked up the front end and there is a little play in the front wheels. If you grab the top of the tire and push in and pull out, you can feel the wheel rock back and forth. But not if you do the same movement grabbing the tire from the front. The amount of play is the same for both sides on the front.
Is this normal?
EHmotorsports
Beaverton
Shouldn't have any play top to bottom. Get it on stands and check to see if its the wheel bearings or the kingpins moving.
Might require help from a friend to ether move the wheel or look under the van.
galant651
twin falls, idaho
probably wheel bearings, i work for ford and ive seen alot of them come in when other shops have done rotors or ball joints and the bearings arent preloaded correctly so when you drive it they loosen up and are too loose.
galant651
twin falls, idaho
if its loose. the nut should be tightened while the wheel is spinning to center everything and get even preload. slowly get it tight so you can spin it but it drags. then loosen and lightly retighten. check for wheel spin and drag. the nut should be tight but the wheel should spin fairly easy. you should know pretty easily if the nut is to loose.
