Oil pan replacement advice/top tips?
blacksheep
Urbandale, Iowa 50323
I seem to have a leak...just great. Its not the turbo return line, which I expected. It seems to be coming from the oil pan on the drivers side corner by the oil filter housing. It looks like my pan took a hit to the middle or had a jack used on it or something, dented.
Wondering if this is what caused it.
Anyways, assume all I need to do is:
1) drain oil
2) remove turbo return line
3) remove downpipe
4) remove pan
5) remove gasket nastiness
6) new gasket and pan - Anyone know torque specs off top of their head?
1) I am using a NAPA Spectra Pan (Same thing rock auto sells) and a felpro gasket. Should I RTV anything?
2) I doubt I can find the return line gasket at NAPA, maybe they have it. Do I need to replace it?
3) Anything else I need to ensure I don't f*** up?
Thanks much!
ktmrider
Tempe, AZ
Quoting SleepinGVR4:
Never used a gasket. Always used the gray rtv to seal it. Never had a problem.
This. If you can't find the gray/high bond stuff at an auto parts store hit up a motorcycle shop. 2-stroke cases use it for airtight seal, they are under the name of ***Bond, with *** being the brand of motorcycle ( HondaBond, YamaBond, etc ).
Torque is 4-6 ft/lbs or 6-8 Nm.
galantrevolution
las vegas, nv
Also do you know the you have to remove the transfer case to get the oil pan and the also remove the lower support on the left side to get the pan out
You will likely want a new return fitting gasket (and I double them up on the advice of a 25 year Mitsu tech).
blacksheep
Quoting galantrevolution:
T-case? Please tell me this is not true! Damn it, thats more work than I want to take on! /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif
Lower support brace? Does this require suspension removal?
blacksheep
Quoting iceman69510:
I ordered 2 per your advice and 2 new bolts and the o-ring gaskets as well. Thanks, Icee!
blacksheep
Quoting ktmrider:
yay, I have hondabond left over from my s2000 days. Thanks, boss!
blacksheep
Transfer case is not that hard.
No suspension removal for the cross brace.
draining fluids and need new fluids? Take off driveshaft? Any additional gaskets needed? /ubbthreads/images/graemlins/crazy.gif
G
zompton
Don't forget the two 6mm bolts and their correct location.
Quoting blacksheep:
Remove five bolts, slide it off of transmission output shaft, slide driveshaft out and let it hang. Keep rear of xfer case higher than front so that fluid doesn't leak out. Install is reverse of removal. Super easy.
You can also leave the driveshaft in and just let the whole thing lay on the ground if the car isn't too high on the jackstands.
blacksheep
Quoting turbowop:
Quoting blacksheep:
Thanks wop! I am getting old for stands, back hurts LOL. I am hoping my friend can help me in his shop with lift. Hoping he has tranny jacks or something to hold the tcase and shaft up. I will have to hang the downpipe/exhaust as its all one piece welded up all the way back with no cat!
ktmrider
Tempe, AZ
Quoting blacksheep:
Quoting G:
where these bolts at g-dawg?
The ( engine ) front pan bolts are shorter than the rest due to proximity to timing belt. Easy to spot them when standing upright together.
Otherwise you'll get some real purty grooves in the belt.... /ubbthreads/images/graemlins/ooo.gif
And yes the TC remove/sag/replace like Whop mentioned works great, no lost fluid and easy to get at all the bolts.
DynastyLCD
Harwinton, CT
Quoting se7enine:
Toyota also makes a bond for gasket use
^^^ THIS!!!
it will cure any and all oil leaks you may have.
also, if i remember right, you will need to loosen the bolts that hold the driver's side halfshaft to the block. i think you can get away with leaving that shaft in there somehow, but you will have to loosen it to gain the clearance needed to get at a couple oil pan bolts
