Oil filters.
gvr4ever
central Indiana
What oil filters are you using now?
Wix are apparently made in China now. OR, Napa Gold is no longer really Wix? Let me know if Wix is still good...
I ran out of some MANN filters I bought earlier. Or, on the last one with a young oil change on the car.
Just curious as to what you guys are running now.
r4pt0x
Bavaria / Germany
I'm always using the genuine "made in japan" filters: MD322508 (stubby/wide variant) or MD360935 (longer/shallower variant). They have the proper, thick yellowish filter mat and a magnet.
Most aftermarket filters use thin, cheap filter paper and have no magnet. To achieve the longer service intervals demanded nowadays they also often have either a weaker spring for their bypass or no spring-loaded bypass at all (i.e. they always let a certain amount of oil bypass the filter).
It's not that those filters cost an arm and a leg, so why cheap out on such a vital part?
4Grim
Orlando FL
I only use Wix or OEM Mitsubishi.
Wix has several manufacturing plants globally, but more of their plants are in the U.S. They do have a manufacturing plant in China..but its possible to supply product in that region. Their main plant is still in N.C.
Their filters are still quality top notch stuff and continue to prove it with independent tests.
gvr4ever
central Indiana
This is what I saw that started the thought process. Rewatched it and it looks like Napa Gold is now made in China, not Wix. Sorry for the confusion.
I'll likely go OEM. I'll never pretend to be an expert, but I've watched many videos where they measure filtration and oil pressure. Seems like overall, the higher the filtration is, the lower the oil pressure. Being a turbo, that feeds oil to the turbo (for the near stock that still have an oil feed turbo), the more near stock oil filtration is, the closer to stock oil pressure is where I'd want it to be. For my DD turbo Kia, I just ordered Kia filters in bulk to get the factory oil pressure they want, more than the best filtration I can find. I don't do extended oil changes, so I'm more interested in designed factory oil pressure more than anything.
