ODB Plug has no power
EgonOlsen
Denmark, Europe.
Yesterday I finally got my ECMLink package. Was so exited.
Went out and just got no connection error. /ubbthreads/images/graemlins/frown.gif Should have known it was too easy.
Did some readings on the plug. pin 1 pulses as it should. pin 12 is ground but there is no voltage on pin 10.
So is there a fuse connected to that I can change?
If not, where can I draw power from?
I have a spare plug. if I want to install that 1 at the Ecu, what pin do I draw power from there?
Hope someone can help /ubbthreads/images/graemlins/smile.gif
rgeier11
Chicago Suburbs, IL
You will have to back probe at the ECU to see if there is around 4.5V coming out of it.
You will need to measure voltage at pin 2 of the large connector (of the three ECU connectors).
See this chart
Edit, just saw that you live in denmark. I don't have wiring diagrams for their ECUs.
EgonOlsen
Denmark, Europe.
You seem to misunderstand. Pin 2 on the ecu is the diag port. thats = pin 1 on the ODB, that is working. Its the flat 4.5 volt on pin 10 of the odb plug thats not working. thats afaik NOT pin 2 on the ecu?
And its a US VR4 so.. /ubbthreads/images/graemlins/wink.gif
Edit: Hmm maybe I misunderstood :p
Plug ECU
pin1 pin1
pin10 pin2
pin12 ground
Is that correct?
