Not going into gear new problem
vr4199
Providence,RI
Any help would be appreciated.
I was having difficulty get my car into gear and someone told me it might be my slave cylinder. Since the master was replaced 2 yrs ago so i had someone change it bleed the clutch and now its worse. I dont know what to do now please help
thanks
UPDATE
Well I need some input again i had my slave installed over a month ago.
shifting was kinda rough but it worked.
This morning when i when to start the car and press the clutch pedal it just went right down to the floor zero pressure what so ever.
I proceed to open the hood and check the clutch fluid and its empty.
I'm assuming the slave that I got is no good.
My question is should I get a new slave and or clutch master cylinder.
any help ASAP would be greatly appreciated
Thanks
Barnes
Richland, WA
So you put in a new slave cylinder recently, and bleed it? Who is 'someone', you had a shop do it?
Sounds like you just need to properly bleed the clutch line.
