So, got the car all back together today and tried to start it up. It cranks but doesn't even try to fire.
1. I started troubleshooting by verifying the mechanical timing was good, and it was.
2. Next, I verified I have spark, and I do.
3. Next, I verified I was getting fuel from the pump. I activated the fuel pump using the test terminal and using ECMlink's interface. Both worked fine.
At this point, ECMlink began showing DTC 0041 (Injector Circuit Malfunction). I cleared the code and it reset again after some cranking. After seeing this, I grabbed a spare injector from my parts pile and plugged it into the harness. I can feel it clicking. I probed the injector plugs, and with the ignition on both terminals on the injector plugs are showing battery voltage.
1. I thought I may have wired in the quick disconnect plugs incorrectly. I verified they were all right according to the diagram below:
2. I grabbed about 5 different injectors from my parts pile. All were either 450cc or Evo 560cc. The all measured 2.6 ohms. I measured the ones on the car, and they too measure 2.6 ohms.
3. Next, I tested the resistor pack according to the diagram below. Each set of terminals showed exactly 6.1 ohms.
4. I swapped out the ECU just for fun. No change, same issue.
So, even though the resistor pack checked out, I'm leaning toward it being bad. I'm at a bit of a loss. What else would cause a 0041 code?
