No start. HELP
Flip4G63
Abilene Tx
Ok..
bone stock 1990 Eclipse GSX
I swapped in a known working motor (from my car) into this one.. i pulled the whole running motor and dropped it in didnt mess with the timing belt at all.
Its getting spark and fuel. WTF?
swapped 2 CAS's brand new BPR7 plugs @ 27 i drove this car to my house with a cracked block and just put the motor in and now no start.
I'm stumped! mabe some one can think of something i havent.
some one help figure this POS out.
How long has the motor sat? It may be having problems building compression. Have you checked the compression? Try putting a small amount of oil down each cylinder to see if that helps seal the rings to get compression up.
Flip4G63
Abilene Tx
compression numbers look good. /ubbthreads/images/graemlins/dunno.gif
I'm getting code 14 and 41 now though. /ubbthreads/images/graemlins/rofl.gif f***ing car.
Flip4G63
Abilene Tx
Yea i know.
I looked it over and all was good it tested out fine. cleared the codes and they havent came back.
I'm lost. Ive done everything i can think of. i have good fuel and spark.
Ive swapped ECU's, plugs, wires,
it sounds like a timing issue but i cant find it. timing is dead on.
/ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/idea.gif
