Specter
This problem has started since the last two days. If i cruise around everything is fine, but if i accelerate the car even a little bit, i instantly loose brakes. The brake paddle gets all tight and there is no travel, if i press it the car does not respond at all as if there are no brakes. If i leave it for 2-3 seconds ( the car is still running on the road ofcourse) the brake pedal gets back to normal and the brakes work fine. What could be the problem? Do i have too much air in brake lines? Or is the master brake cylinder dying? Oil level has dropped around 35% since i last checked like 2 weeks ago.
