no blinkers,door locks,sunroof,antenna, NO BLINKERS
yeti
san diego california
Ok so I'm tired of driving around scared shitless I just got the galant on the road fresh registration and smog, I wired my own wideband in and in the process made sparks and probly shorted all of the above.
My question Are there fuses/relays controlling all of the above stated in title???
yeti
When my alt. Fuse was out the electric door locks didn't work.
Could I rig the blinkers up to constant power.....I really need blinkers before I get pulled over.
jepherz
KC, Missouri
Quoting yeti:
No, that's a good way to burn your car to the ground.
Boostdtalon
Buckley, Wa.
This is why you always disconnect power when doing anything electrical. Have you gone thru and checked all your fuses? Trying to wire constant power is a stupid idea and is just asking for even more problems. I would highly advise from doing that. Go thru and check all fuses with a fuse checker before you do anything.
yeti
Ok , should I check for current?
And does anyone got a picture or a link to the fuse panel cover that states where all the fuses go, and also my tail lights, reverse lights, auburns, none of it works.
I know I am a retard for not disconnecting the battery cable.
yeti
It was number 17 fuse which controls A LOT.
But stil don't have blinkers.
And I don't see a fuse that covers turn signals on the link in my other post.
yeti
Ok so I fixed door locks tail lights, sunroof,belts, and reminder key sensor,
Stil have no blinkers,
Are the blinkers connected to the hazards some where
Like if I cut all the wires from the hazard switch button would that take out my blinkers?
