New transfer case seal is still leaking
Saskatoon, SK, Canada
Just replaced my tail seal with a new OEM one about 5 minutes ago and filled the transfer case up with fluid. I turned the input to see how it felt and fluid just started drooling out of the tail. /ubbthreads/images/graemlins/dunno.gif Not sure what to do about it, I slowly hammered it in using some soft wood and it seems to be bottomed out. Any ideas? Thanks
Can you clearly see the leakage point is between the seal lip and the drive shaft itself? You mention a new seal, but are you sure there was no inside lip damage after you tapped it in?
Lastly, it may not need to be put in until it bottoms out. Sometimes a groove is worn in the shaft allowing leakage by the seal and the seal may need to be put in either a little more or less to make sure the new seal lip is NOT aligned with any wear groove.
I am presuming you have the new sealed (recall) yoke design and it is not leaking from there.
Yeah the driveshaft isn't in it haha, I'm an idiot. Just waiting for my parts to come in, I bought new carrier bearings, u joints, Lobro Boot kit, and the revised yoke. Should I just fill the t case while it's in the car then? It seemed easier to do while it was out that's all.
mooserage
Seattle, WA
Learning is what its all about. You'll really need to fill it on the car to make sure it has the right amount of fluid. I suggest getting a decent fluid pump to reduce frustration in filling it. Similar to the transmission, you will fill it to the point that it is level with the fill plug, but you don't want to overfill it either.
