New owner of 1209/2000
trevstuh86
Active member
Mansfield, Tx
Hello again, my name is Trevor. I am the new owner of 1209/2000. I know this car has some history on here, and looking forward to bringing her back to the glory days. I have a issue to tackle which is oil mixing in coolant. There is no coolant in the oil, it doesn't overheat. I'll be checking over her when I get some time off from work. I'm happy to have it, and ready to make her road worthy again.
thomcasey
Indianapolis, IN
You should check the turbo AND the Oil cooler (in the OFH). Since you are only getting oil in the coolant, it is leaking where the oil pressure is higher than the coolant. the FP turbo's normally wany oil fed from the OFH, so both locations will see higher pressure
trevstuh86
Active member
Mansfield, Tx
The oil feed is coming off from the stock location off the head. I just got around to messing with it for a little bit before taking off to work. The turbo will need to be rebuilt, it has in and out play but not side to side. I have a ebay 16g from cx racing I will put on and see if oil still mixes in with the coolant. I know when I checked out the wastegate on the car it's cracked as well. Maybe this weekend, if texas weather doesn't act out i'll be swapping the turbos.
