Need part numbers, Rear subframe bolts etc. CAPS help please
Hey everyone,
I am currently undergoing a restoration on my VR-4 and need some help with part numbers/places to buy the rear end bolts and misc hardware undercar.
Things I need:
-All rear subframe bolts, basically every bolt associated with the rear end. (ie. Mounting bolts, diff bolts, control arm bolts, trailing arm bolts etc.)
-The "triangle" mounting studs that bolt to the chassis via 3 bolts to hold the rear.
-Driveshaft carrier bearings, u joints, nuts to mount it
-Brake line/fuel line little brackets that mount the long brake/fuel hardlines running underneath the car
-Front subframe bolts, control arm bolts etc.
-Front/rear sway bar endlinks
Basically I am looking for screen shots or just part numbers for everything underneath the car if possible.
If you can help me out or send me in the right direction, I would greatly appreciate it. I've been looking on JNZtuning's website and have found some, but figured this might be easiest. Thanks in advance.
Yes I have, do you have a link for the download? I was under the impression that it couldn't be had for free? Any pointers would be appreciated. Also I am using a Mac computer if that helps, I've only found ones for windows.
Spyke169
Greenfield, Wi
I was going to mail you the copy I got off my work computer, but this may be easier.
There you go Raatz, not sure if you need a name and password, but I sent you a pm with mine if you do
