Need help! Engine stall problem
TFT880SNY
New member
manila
Whenever i press the gas half or full throttle, engine stalls after i release the gas pedal. I have a feeling that it is a MAF problem not giving the right signal to the ECU because of the HKS SSQV installed. Anyone has the same experience? And if so, is there a solution for this? Hope to hear from you soon guys! Thank you!
vtecds1
Las Begas
Is it recirculated or venting to the atmosphere? I've had some luck before venting to the atmosphere where it would not die out, but some had problems with the car idling and stalling. Also, was it having problems before or did it start after the install? Did you do anything else to the car?
