Need Help!!!!!!!!!!!!!!!!!!! drivetrain problem
xxxspeedxxx
Active member
Modesto, CA
Hey guys, i need help figuring out this problem. So while i was driving GVR-4 home from school i stopped at stop sign, and then i did a mild lunch, and then i heard something brake under the car, then i started accelerating and started hearing a wobble, slight scrape, its a smooth noise. when i give it gas the rpm increases rapidly but the car is slowly accelerating. and the noise gets worse as i accelerate. there is no noise while i am cursing, however when i give it gas it starts making a scrape noise, i can hear it coming from the rear passenger side.
from research I've done so far its not a transmission problem because i can shift into all gears with ease. could it be a Transfer Case maybe?????
my knowledge is limited when it comes to transfer cases , so hopefully you guys can help me identify this issue before i take it to a mechanic.
Thanks
5OF2k
colorado springs, colorado
Kind of sounds like an axle to me. Park the car, jack it up onto jack stands, and roll around underneath it. You'll be able to see of anything is abnormal by doing that.
If I understand your post right, you are saying RPM is increasing, and the car's speed not increasing proportionality according to the selected gear. The most likely thing that can cause RPM to vary independent of transmission speed, is a clutch issue. A slipping clutch would allow the engine speed to increase/decrease without regard to transmission input speed. Basically I'm saying from what it sounds like from your written description, your clutch is damaged. Looks like it's time for a big price drop in that sale thread you have posted...
Quoting 5OF2k:
That wouldnt explain the noise he hears coming from the passenge rear of the vehicle though...
Noises can appear to come from somewhere they actually are not...However I've never seen an axle that allows RPM to increase rapidly, yet causes the car to slowly accelerate. Then again, I'm just going off what he said.
xxxspeedxxx
Active member
Modesto, CA
if its a clutch problem wouldn't the clutch be slipping. or hard to put it into gear. idk. a bad clutch is possible
lol i a not going to sell it until i fix it, so the price will not be dropped. lol for now.
I would roll back under the car, remove this plate and see if you can find any abnormal debris or see anything screwed up.
Quoting xxxspeedxxx:
Sounds like your clutch is slipping?
Racah15
Colorado springs CO
...when i give it gas the rpm increases rapidly but the car is slowly accelerating
Not to be an ass, but didn't you say this already? Usually when this happens your clutch is slipping. Do you have a sprung clutch? If you do, you may have broken a spring. ACTs love to break hubs and strip splines as of lately, so you may have gotten one from a bad batch. Although according to your post, it seems unlikely to be this. You say you're in school, I'm taking you're not taking any English classes? Usually nothing happens to my car when I take it for a mild lunch, and if there is no noise when you are cursing, then you aren't cursing.
Just giving you crap kid :p
brisvr4
brisbane australia
Crawl under the rear of the car and GRAB the axles and give them a GOOD shake.
If the axle broke inside the pumpkin you won't see it.
Both of my rear axle breakages gave the same type of symptom as you are describing.
That plus that fact that it happened immediately after a launch points that way.
AWDPower
Vacaville, CA
It also sounds like an axle to me, mine did the same with a broken axle. Follow brisvr4's advice, I bet an axle broke at the splines.
IncorpoRatedX
Arizona
sounds like the rear axle broke inside the diff, my stock 3 bolt did this years ago during a launch. Same symptoms as the thread started explained.
Sounds like it needs to be sold to someone that will take better care of it, rather than launching from stop sign to stop sign.
xxxspeedxxx
Active member
Modesto, CA
i want to thank you guys for all the help, it turned out to be a broken axle? /ubbthreads/images/graemlins/banghead.gif
quick question guys, if i am going to swap a 4 bolt rear end, is a 4 Bolts Rear Differential with Axles and caps is all i need to make the swap??
