mystery water
transparentdsm
Cherry Hill, NJ
so i got in 1078 today and its been raining pretty hard out lately, only to find that the drive front floor and the passenger rear floor are soaked. now none of my seats are wet, the headliner is dry, the doors are dry, nothing is showing signs of water coming in. does anyone have any idea where i might be getting water from? i pulled the carpet back a bit on it so i could try to identify, but there is to much rain coming down. its getting back, the interior is starting to smell moldy. im prolly going to have to gut the car.
presterone
brunswick maine
What are the sunroof drains like in these cars? I've never had them apart but I'd be suspect of something like clogged drains.
transparentdsm
Cherry Hill, NJ
^ is that something that i could pull all the trim pieces off for, scrap and clean up and then just reseal? also how would this get to the rear passenger floor without making the front passenger floor wet?
Quoting presterone:
non-sunroof. and as i said its not leaking from above, a clogged drain would leak from the top. i only have water on my floor.
bad door seal, bad windshield seal. Pull your trim out so you can see the frame. Then shut all doors and have someone spray a hose on the car, then look for running water. It takes time to fix these things. Sometimes it can be something stupid simple to fix, but take hours to find.
boostx
Orlando, FL
Quoting G:
Probably corrosion in the windshield seal area.
I had the same problem with #23. Had to remove and reseal the windshield.
transparentdsm
Cherry Hill, NJ
Quoting prove_it:
i just got a break in the weather and was able to remove all the seats the carpet and the door trim, but this is the direction i was headed in to begin with. all the door seals seem good, but who knows. for all i know the last people in the car didn't shut the doors all the way when they got out. no one has driven the car in 3 or 4 days and i pretty much dont drive it at all. i always sit up front though and that floor was dry...
cheekychimp
East Sussex, U.K.
I haven"t got much to offer in the way of advice on where the leak originated but many years ago, I left my sun roof open at work by accident and during the course of my shift the heavens opened. I came back to an absolutely soaked car. I wiped down the dash and centre console, drained out the cup holders etc but ended up just locking the car up and getting the bus home. The next day I came back and it was 38 degrees and brilliant sunshine and the car was like a sauna ... Literally! I mean the entire car was filled with steam. I opened all the doors and switched on the fan to clear it all out and the cloth, carpets, door cards etc were absolutely bone dry and so so clean. It really was a poor man's steam clean and I never had any issues with smells etc.
The only thing years later was I discovered some rusting on the seat rails. So I'd say just get the car under some sun if the weather is warm enough.
G
zompton
Not in the red circle but above that below the glass is where they corrode.
transparentdsm
Cherry Hill, NJ
thank you very much, i actually just solved this issue about 3 days ago. after i took the carpet out of her car she was upset that it looked so shabby so we decided to dye the carpet black. while i had the carpet out i borrowed my neighbors pressure washer and hosed the snot out of the car with it.... the door seals are all messed up and letting water seep in behind so i just bent the top of the doors in a little bit and presto no more water in the wifes car and her carpet now looks a lot better. there are still some stains in the carpet, but there was a lot of rust and other sh*t really stuck in the carpet.
